Much to my surprise, the graphite rod just arrived in the morning's mail. I was expecting no earlier than Monday.
Time to remake the piston with a tighter fit.
good luck, cant wait to see if this fixs it.
I do not know if it's okay or not, I just try to make the piston sealed but move in the cylinder as smooth as possible.I need to make the piston virtually stuck in the cylinder until the cylinder is heated up, .
the engine stops when starting from cold as water from the combustion condenses inside, and increases drag, this is usual...
once the temperature of the engine reaches its running temp, in 2-3 min, the engine runs indefinitely....
