I don't envision this as a build thread, because I have so little to contribute, but I could use some help with questions as I muddle through my build of this engine, from "The Shop Wisdom of Philip Duclos".
I'm going by the book, and now making the second part, which is the cylinder. After cutting to finished size, cutting the fins, turning the shoulders, and drilling the bore up to the biggest drill bit I own (1/2"), the next operation is to bore it to size. The plans say to bore it to 1.00 - which is funny because that's only two decimal places. The piston's drawing says to turn it to 0.9980 to 0.9985. Four decimal places.
The piston isn't ready to fit to the cylinder because the order of the build (in Duclos' book) has me build the cylinder and set it aside. The piston is a few parts in the future.
I bought a CRS steel bar for the piston (the drawing says "bronze, cast iron, or CRS"), 1" diameter, which is really a bit undersized at 0.9990 to 0.9984. I figure when I put that in my lathe to do the turning, I'll lose more than .001 just turning it in the lathe. I don't know what my 3-jaw chuck's runout is, but .001 is way too good for a 3-jaw.
What I'm thinking is to bore the cylinder to something smaller than 1.000, then turn the piston to size. Say I bore it to .990 or .980. I shouldn't have to go as far as .980, but just to make sure I can turn the piston to the right fit. The only problem I see is that I bore the cylinder without knowing what size I can make the piston.
Does that seem like the right approach?
CFL Bob
CFL Bob
