- Apr 3, 2017
- 232
- 120
Hi all,
after procrastinating for months and clearly overthinking the problem of how to make the crankshaft for a twin diesel I/C engine, I decided I needed to be making some swarf over Christmas to decompress from work. After poring over the MotorBoys plans for a while I ended up on Adrian's Model Aero Engines and found plans for a lovely simple little engine called the Holly Buddy (https://www.adriansmodelaeroengines.com/catalog/main.php?cat_id=214). Nothing I haven't tackled before really apart from a front rotary valve in the crankshaft (my previous builds have all been RRV or sideport).
I've been beavering away on it for a couple of weeks so thought I'd share a few pics. This isn't a step-by-step thread as I just jumped in to the workshop and got cracking but if anyone has any questions on any of the parts shot an I'd be happy to share more pics.
The engine might be ready for a test run this weekend to the less time on my computer and more time at the lathe the higher the chances. I also want to have a go at anodising the prop spinner (any good tips on making prop spinners btw? info seems v scarce on the web) and cylinder muff so will share some more detail when I get to that.
Anyway, hope this is of some interest to someone out there in the 'engineverse' .
cheers,
Patrick
I use every build to improve my dodgy CAD skills too. I modelled this one to the point of being able to animate the turning crankshaft, piston, cylinder etc. Happy to share the files if someone wants a play.
making the crank case. (BTW the camera is lying. The surface finish looks nice after the crud and oil has been cleaned off )
Taking some metal off on the crank case making it look a bit more Nalon Viper style.
Thought I'd go for an axial rather than a radial mount (partly for ease of slotting into my running mount later rather than screwing into a piece of wood)
cheers,
Patrick
