Mosey said:Seriously, is anyone building a Silver Bullet?
I have not seen a build thread for a silver bullet. I do have the casting set for the SB and the Hurc.
You could start a build thread and keep us up to date!
Mosey said:I have been building the SB for about 10 years now, on and off.
Maybe you would like to see some snaps, sometime, but understand, I am a beginner and it won't have that beautiful finish yours has.
Mosey said:I milled the cam similarly to your way, after AutoCADding a cutting plan, and building a cam milling degree'd wheel. It came out very nicely.
A true work of Art.stevehuckss396 said:Well.... I think this project is about finished. I have tuned the carburetor about all i can and have it running to a point that makes me happy. I plan on some suttle changes like a small container under the overflow tube in the radiator. For the most part
I'M DONE!!
www.youtube.com/watch?v=1-JRQGPswVA
metalmad said:A true work of Art.
is that a electric starter that u put through the radiator?
Mate I love the whole thing.
Pete
If you ever decide to build it, I have drawings to fix the crank shaft problem. I also have the head for the odd bank and a distributor set incase you cant get a hold of MJN.
Hi Steve
I realize this is very old thread but I have just bought the PeeWee casting, is it possible to get the drawings of the crankshaft and anything else you might have to help me along, obviously I will meet any costs if there are any, hope you can help?
Regards and thanks
Hi Steve
I'm obviously getting confused ( very easily done) yes I did receive the full set of drawings but I was under the impression that you had made an updated drawing taking into account an error of 20 thou you had found, I will have to convert to metric anyway so hopefully I will work out any problems then, I think the drawings leave a lot to the imagination anyway!!!
Yes I do have an alternate set but they should not be used on a build that has been started with the old set. There is very little in common with the old set. If you are still interested PM me an email address and ill get them to you.
Looks very good Steve every thing nice and shinnyWell after more than 13 years Peewee got a make over. The pipes were in bad shape so they were replaced. I the ignition fixed. She got her paint touched up and her brass shined up. She's ready for the new show in Indiana and another 13 years.View attachment 149369View attachment 149370
