goldstar31
An accent is not good for business.
One - you will note the correct expression- learns to 'scrape one's tongue'.![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Yes, I've watched Enot for a long time. And a bundle of others too.Enots talks about parting tools
Heath Robinson, eat your heart out.
Ah yes-- but does his humour travel, please? A bit like Gerard Hoffnung.
"Heath Robinson" is "Rube Goldberg" in British.
I have a parting blade holder that provides 5 degrees rake but also use a classic parting tool in a standard QT holder. To avoid grinding a top rake angle I place a suitable thick spacer under the tool front, presto structural rake without grinding.He had a thin piece of metal wedged under the cut off tool.
In The Home Shop Machinist magazine years ago there was an article from a Guy Who regularly parted off 11" and 18" bronze. A picture showed a piece of 11" being cut. He had a thin piece of metal wedged under the cut off tool. Not to burst anyone's bubble, including Mine.![]()
Had a bit of trouble finding the Enots parting tool videos, so here is the one that compares tools:
And here is the one on grinding a parting tool:
In another video, I notice that he is using the insert tool type which I use. I have no trouble parting off with carbide inserts.
George
I think your lathe would have had a much easier job parting that steel if you used the lowest ratio on your pulleys.
