Lohring is an expert but I think I can say 'perfect' is a never ending, perpetually moving target. Today's record breaker will be tomorrows broken record.
Ambient density variation makes its way into several tuning factors throughout intake, power & exhaust. There is interplay & tradeoffs, you don't get something for nothing. A big part of high performance 2-stroke power comes from tuned exhaust - sucking intake charge out past the exhaust flange, but then reverse packing this charge back into the cylinder via the reflective wave, essentially 'boost'. But its all an orchestra of balancing many factors: compression ratio, timing, gas ports, distribution... the more you learn about 2-S the more you realize how complex they actually are.
Sounds like it. Hmm... Perhaps it wouldn't be such a bad idea to get a hold of one of those hobby king twin cylinder engines and dissect it. I would be interested to see what the case volume is with the crankshaft installed compared to the displacement of the cylinders.
I would have to wait till they are back in stock.
