Conventional wisdom has it, that engine flywheels belong on the end of the crankshaft. I don't have any problem with that, and have built a number of engines exactly that way. I have an idea in my head for a new, rather strange i.c. engine to build, and it will be air cooled. I don't want to install a separate belt driven fan. It would suit my purpose extremely well, If I had a 2" diameter spur gear on the end of the crankshaft, meshing with a second 2" spur gear which was attached to the face of a flywheel running on a dummy shaft with ball bearings. This would put the flywheel in line with the cylinder. Instead of conventional spokes in the flywheel, I would use flatbar spokes set at a 45 degree angle, thus creating a powerful little "fan" to blow air over the cylinder. I don't see any reason that it wouldn't work, but I have never seen an engine arranged that way either. I believe the spur gears would have to be made from some relatively strong, tough steel, perhaps 4140, or even purchased hardened steel gears. Has anyone ever seen an engine set up like this?---Brian
