Novice from Phoenix, AZ
ke7hr
Active Member
Hi to you all on HMEM from Phoenix, AZ!
My name is Paul and I have a 3 in 1 small machine and will be building some model engines. The HMEM is great. I have been lurking for a couple of weeks, reading many of the posts and getting a sense of what goes on here and am very impressed. My machining skill is at a complete novice level and am trying to get my machine to be accurate (within reason) and learn how to do things in an accepted mannor. I am enrolled in a community college class and pick up nuggets of good information in every class. The learning curve is steep, but fun.
I uploaded a modified Jingle Bell Motor and that will probably be my first attempt at a motor. It is quite simplified from the original to allow my manual machine (and novice skills) a chance to complete it.
Some of my other major hobbies include amateur radio (KE7HR) and caving - as can be seen by my avatar graphic. I often combine the hobbies and have done extensive radio work from deep in caves to the surface.
Welcome
the jingle bell motor looks like a good motor to start with.
-B-
Paul,
Welcome to our forum.
Best Regards
Hey Paul,
Welcome aboard and you know the drill th_wwp
Tony
Welcome to the forum Paul. I don't know anything about a 'Jingle Bell Motor' so I'm interested to see what it is. Have fun!
I am starting the build today and will start a thread to report progress.
The original Jingle Bell motor apparnetly had a loose bearing and the flywheel made a noise as it rotated (Jingle Bell noise). I hope mine is quiet...
By that naming system, one of my early Stirlings should have been called Box of Rocks. ;D
