- Aug 8, 2009
- 929
- 12
Or so my theory goes...
This is kind of a long boring post, my apologies.
Having just finished my Elmer's #45 single compound, I was confident it would run first time out. Too confident, it seems. It's not running at all and after almost 8 hours poring over the design, checking the valve travel, tweaking the eccentric and pressure and making a few other adjustments, I had to call it a day and think it over in the air conditioned house, with a coconut Rum and Coke in hand.
<Edit:> This cylinder is a single compound variety and as such, the High Pressure is fed below the piston and then cycled above the piston, then out to the exhaust hole.
It's generally assumed that with a slide valve, since it is always over the exhaust port, steam pressure will press it against the cylinder forming a sort of seal as long as the surfaces are finished properly. That is what I've been assuming but now I think there is another scenario and it may be causing my problem here. On my engine, I noted that when the valve was at the end of its travel (far left), the piston in midway position will shoot back to its lowest position, it is under pressure but it isn't supposed to be because its in the exhaust cycle. Observe the pic below. High pressure feeds the rear of the piston and moves it towards the top of the cylinder. For the area above the piston, this is the exhaust cycle. The valve is moving to the right during this power stroke, slowly covering up the high pressure inlet port. As this is happening, the valve begins to open the port to the other side (top) of the cylinder and ports the high pressure to that side. This forces the piston back down. The cycle repeats. What I am seeing is when the piston is midway and the valve is as far as it can go to the left, connecting the volume above the cylinder to the exhaust hole, the piston is shooting back to its bottom position as if there is pressure above the piston.
The way I see it, there is only one way this can happen or rather, only one way I can visualize why this might be happening. The valve is not being held against the cylinder, it is lifting and high pressure is finding its way to the exhaust ports. When the valve is all the way to left, there is existing pressure from the area above the piston pushing up against the slide valve and if that valve has play in the Z direction, it will lift and then here comes the high pressure from the steam chest cavity. I can hear and feel pressure escaping from the exhaust valve at this time.
At the very last I checked the slide valve. I pulled up on it and what do you know, it pops up about 20 thou. Tomorrow I will make a new nut for the valve and make sure it seats the valve against the cylinder with no play. I know I can't make it too tight so there's a balancing point there.
So there's my theory. Does it hold water? I'm pretty new to this steam engine stuff. :idea:
-Trout
-Trout
