Hi folks
I`ve been building this engine the last 3 months, before knowing HMEM wisdom (YOUR wisdom!) was at the reach of my hands.
The engine is my own design, i have a few notes and draws of it with a few bugs discovered during construction (i hate that!) but, after all, it is going fine. (unless you find more bugs!, please, find more bugs before i continue!)
Ok, now the pictures..
This build started before i join this forum, so no pictures where taken before this stage.
The next pictures show:
Crankcase
Cranckshaft (hiden inside, more details will follow)
Pistons (ringed pistons! what a challenge!)
Con-rods *
Cilynders and liners *2
Some words about the *
The con-rods where (are!) a frankenstein.
The big ends end up smaller than the small ends!
I`m not sure if it is a problem or not, but they are like this to save a piston rebuild.
While drilling one of the piston pin holes, i accidentally moved my cross table X axis about 1mm. I end up drilling 5mm instead of 3.5mm to save the piece.
Cylinders: The liners where about 8mm short due to a miss calculation on my drawings.
The liners where so square and polished that it was more than a waste to remake them (i had no more steel to do it!).
So, i made a nice hack... i enlarged by 8mm using the sleeve. The piston travel is ok anyway.
More in the next post.
One more thing... besides learning machining, i`m learning English. Please, let me know if i anything could not be understood!
Norberto
Crankcase
Con-rods *
Norberto
