Decisions decisions.
IMHO if I had to choose a lathe from the import market and had about 1300 limit I would put my money on the grizzly go602 10 x 22 .
same actually less money than the new 8 x 16 but it is twice the lathe.
the 768 you need to switch gears for each threading task. the 10x has more power more swing ... the 10 x includes a 4" chuck the 8X does not.
The only real advantages I see with the 8 x is infinite variable speed and the tach. . While nice to me not enough reason to give up all the advantages found on the 10"
The 10" you will likely have to take as much off as you can to get in basement.
But where there is a will there is a way.
I suggest you download the manual for each lathe you are considering and read them . also carefully read the accessory and specifications list.
the 8" has the chuck mounted with studs a pain to change the 10" has a threaded spindle nose easier to change. .....
Indeed. Now we approach the budget I had mind for lathe + mill.
By the way, why is there seemingly more lathe talk when compared to mill talk? Fewer choices? I take it that going with the Micromark or Little Machine Shop options is plenty for most needs?
Sent from my iPhone using Model Engines
