hey there. im an 18yo "kid"* (*unfortunately not technically )
last year i got a mini mill and made lots of things. a few weeks ago, i made this little air powered engine out of random pieces i had around. i revised it several times, mostly improving the valve system. this was done completely on my mill and with files and dremel. (although 2 days ago i got a 7x12 hitorque lathe, it was not used to build this engine.) here are some pics of the engine. sorry the pix are a little bit blurry because my camera self focuses (very poorly at close distances, no matter how i set it up).
here is the simple valve. it was a mini walbro carburetor shaft from a chainsaw. it rotates side to side and exposes the intake or exhaust port. the thrust bearing ball and retainer keep the valve from being blown out the top from the air pressure.
what should my next engine be? i want to do a 4 stroke air motor because they sound pretty cool. i don't really understand how the valve system on them works tho.
i will try to get a video too. i also added a throttle valve and tried to balance the flywheel a little bit after the time these pictures were taken.
