- Sep 2, 2011
- 1,407
- 415
and when it comes to starting it, seems you need to be able to spin it over fast before it will start to pickup and take off.
My Webster experience has always puzzled me - I have found that my cordless drill, on its low speed setting, will NEVER get the Webster to start; I have to use the high-speed setting on the drill. Meanwhile, though, if the carb is dialed in right, I can start it by hand, holding onto the rim of the flywheel and yanking it over. I wouldn't think the result would be very fast, surely not even as fast as the low-speed setting on the drill - ???and when it comes to starting it, seems you need to be able to spin it over fast before it will start to pickup and take off.
Has anyone else had problems with the roll pins working loose on the Webster? This has happened twice now, thankfully no damage the second time despite both pins escaping at the exact same moment!
I measured the pins and they seem to be the correct size for the holes (about .132 for a 1/8" hole, though there is a lot of variation from pin to pin). Wondering if the pins I bought are no good, or if I should find some extra way of retaining them. Alternatively I could try to replace them with bolts, I suppose.
