Need help with carriage lock for Sieg SC2
Jennifer Edwards
Bridlington, East Riding of Yorkshire, UK
Hello all,
I am trying to find out how to make a carriage lock for my Sieg SC2 lathe.
I have searched the net for hours with no luck finding an acceptable design.
Most of what I have found only lock down a single corner.
Do any of you know where to locate either plans or a ready made carriage lock that will properly clamp down the carriage?
Thanks!
Jenny
Hi Jenny,
Most if not all the lathe saddle locks that have seen are only a single point clamp.
My lathe is a Myford, and the saddle lock is a simple bolt through the right rear corner, going down to a captive nut and small metal plate. When you tighten the bolt it simply nips the saddle to the shear.
In fact I've been threatening to make a ball handled bolt for long enough, to replace the hex head bolt that is fitted as standard to these lathes.
Chuck,,
Thank you for the tips, it is much apprecited. I will tke a look at them all, an hopefully one will be the solution I am seeking.
Jenny
IOF the lathe has an American pattern bed, that is a inverter V way up front and a flat way to the back a single clamp is all you need. That is as long as the clamp pulls the saddle down on the V way. If that is done the saddle can not go anywhere as you are bound inthe forward/reverse direction and the left/right direction.
Perhaps Bristol locking levers would make things easier. Mine came from Axminster Tools in North Shields- not too far away from the Yorkshire Coast
Norm
A waste of time and resources. The corner lock works fine in all applications. The theory that cutting forces tend to lift the rear side of the crossslide is bogus, for that to happen the radius of the part must extend beyond the guide V.
On the other hand, the contraption in the middle of the ways interfere with the Tail Stock to get close to the carriage, a situation often encountered.
How one is going to operate that lever with the Tail Stock in the way?
I had lots of problem parting until I learned to grind the proper tool and select the proper speed and feed. Do not blame the lathe design for your lack of skills.
My junky Chinese lathe has been getting better, more rigid, and more accurate with my age and time machining, I wonder how that can happen.
Thanks again Chuck
seem to have lost the text but this one I did.It worked well
Perfect - Just what I wanted - Thank You!
