jack620
Hi All,
I have a Hercus lathe with a slotted cross-slide. I have the Hercus milling attachment for the lathe, which is my only milling capability. Some time ago I acquired a Myford milling attachment and a Myford vice. Although the Myford milling attachment is less capable than the Hercus, which can be rotated and tilted, it will be quicker to setup. I think it will be handy to have for quick and dirty jobs.
Today I finally got around to mounting the vice on the milling attachment. There are a couple of issues with this combination. I’m not even sure if the two are intended to go together. Perhaps one of the forum's UK members can clarify that?
The slots in the milling attachment are 9.3mm wide, which is a fraction under 3/8”. So I assume Myford intended the user to use T-nuts with 5/16” or 8mm threaded holes. That’s fine, except the notches in the vice casting are slightly over 3/8”. I think using 5/16” bolts in these notches would result in a sloppy and unsightly setup. So I elected to make slightly undersize 3/8” T-bolts from 16mm square stock that fit the slots in the milling attachment.
The other issue is how close the T-bolts are to the edge of the slots in the milling attachment. It looks to me like the bolts will place stress on ends of the slots, thereby risking a cracked T-slot.
Finally, the base of the vice is significantly concave. I intend mounting the vice in my Hercus milling attachment and taking a skim cut with a large fly cutter.
What use did Myford intend for this milling attachment? Was it meant to take a vice, or are you supposed to attach the workpiece with T-nuts and toe clamps?
Appreciate any comments from the Myford owners.
