Fortunately Stew it wasn't ally Bronze
OK Im back with an update on progress. I made a new end plate and a complete set of bushes out of the material that could be bronze, going on Firebirds spiral stripe identification.
End plate and central flue have now been successfully silver soldered but not without further issues.
I gave it a generous amount of solder on the water cross tubes as there is no way to get back into then to fix any leaks once the boiler is completed. The joints cant be seen anyway.
Eventually a degree of success with getting all the bushes installed but it wasnt as clean and tidy as I would have liked. A few globs of solder here and there.
Ive now moved on to the bottom end plate and now had about 4 attempts to get it soldered up. Once it fails its back into the pickle for an hour, quick clean with one of those green kitchen scoring pads (nothing drastic) rinse and a generous application of flux. (I now have some Easyflow paste).
Youll see I have tried Firebirds ring of solder technique hoping that the whole thing would heat up and flow nicely into the joint without any problems. No such luck, hence the 4 attempts.
LESSON LEARNED Dont get your silver solder mixed up. I had had some Easyflow 620degC but in amongst it was some 840degC, no wonder the brass bushes melted before the solder when I tried to blast it with my biggest burner. I am heading towards throwing away all my silver solder and buying new so I know what I have.
Im persevering with getting this thing soldered up, but I've had better success. But that's why I am doing this, to learn.
In the meantime, while all the pickling was going on, I used the time to make myself a safety valve based on a combination of the drawings from Firebird and BogS posted on Firebirds thread A small boiler
That's it for now...
