Finally the moment of truth has arrived. Will the engine run or it will be a dud?
And it runs. But not without considerable effort from my side.
Here is the link
I tried to run it but noticed air leaking out of exhaust port continuously.
The slide valve was lapped into the steam chest. Using 180, 220, 400, 800 grit and finally using a metal polish.
Even after this the engine refused to run.
Valve timings were checked and changed repeatedly but there was no success. All the leaks were chased and rectified.
I was using a tyre inflater as a compressor to run the engine. The pressure was going above 5 bars but the engine refused to start.
Then I noticed that the piston end clearance is only about 0.2 mm at both ends. There was no space for air to come inside the cylinder.
So I had to modify the end covers to allow the air to enter the cylinder. For this I filled out some portion of the boss near the steam passages.
And after some more valve timings adjustment Success.
Nikhil
Here is the link
![IMG_20210826_193342.jpg IMG_20210826_193342.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/82/82573-IMG-20210826-193342.jpg)
Nikhil
