Ooops, I started out on LinuxCNC with a Mesa ethernet card. :fan:
rodw
Are you happy with the LinuxCNC/Mesa card? It seems to be a bit hot? But summer in Brisbane is normally hot I recond
I envy your Linux abilities Rod! Mach is working for me but I'd rather use LinuxCNC. I've tried & couldn't fathom it. The Linux setup is too complex for my meager computing skills.Ooops, I started out on LinuxCNC with a Mesa ethernet card. :fan:
rodw
hello very nice machine
can you tell me where you find this slide bed protection?
i also have made a cnc lathe and i need to protect my motion rails and ball screw
thanks
Ck. the fillet radius box in the rt. upper corner of the wizard. You can type in a 0 and press return. All Mach entry boxes must have an "Enter" key press to accept the new entry value.
Usually that error message simply means that the fillet radius is too large to properly join the two diameters. I think there is a default fillet value of .1 that comes up until you change to a new value & click save settings.
Great looking lathe!![]()
Hi Poppy, some nice work done to date but have you checked that the whole unit will be stable on the support shown as there seems to be a chance of tipping over backwards with the weight of the spindle motor and toolholder fully retracted ?
xpylonracer
