devrimcamoglu
Continue to Learning
- May 4, 2014
- 25
- 45
Hello again, my third project is double acting steam engine with reverse gear. I found some plans about this project on an old (1947) Popular Science Magazine. Link: 1947 Popular Science Vertical Steam Engine
Actually I like Stuart No 1 engines but importing casting kits to Turkey is expensive because of castings weight. Then I decided to convert this project to Stuart No 1 Style and make this converted project by myself from steel and brass.
As you can see, these two machines are very similar actually but differences are measurements, machine's body and reverse gear's designs.
Start Up:
First of all, I converted measurements to metric system then started to machining from crank shaft. Maybe it is a strange startup but I wanted to start from hardest piece of project. I preferred to make crank shaft from monolithic steel part.
I made crank shaft's body from a cylinder block by using my 180x300 Optimum lathe. Then I machined crank wheight couple's dead space by my BF 16 Quantum Mill and shaped T form. After, drilled two eccentric holes from center of part's sideways and mounted to lathe with these holes again.
After numerous minutes, finally crankshaft finished. But when I cut ends of shaft and mounted to lathe again, I saw a little oscillation and after few balancing efforts, everything is O.k.
Start Up:
