Hi everyone !
My new project :
My new project :
I am looking for gears with an outside diameter of about 15 mm for small gearsWhat sort of sizes are you looking for?
LOLTypo Jason![]()
I don't understand what you meancan't you have them 3D printed in a suitable material?
B
You seem pretty adept with 3D CAD, can't you have them 3D printed in a suitable material?
B
I think he does mean exactly what he writes. If you can design the gears with CAD, then you can export them and print them. I think it might be a bit expensive if yo decide to use anything that is not normal plastic.I don't understand what you mean
I must say your anecdotal evidence undermines the plan to provoke a hobbing machine build.I'll add that 3d printed gears work quite well in my experience. I 3d printed a set of back gears for my lathe and they're still going strong years later.
If I were printing them I'd use bevel gears rather than crossed helical. They are more efficient.
3D print the gears, like these.I don't understand what you mean
From what I have been reading, people heat the plastic up to get it soft enough to withdrawl from the sand, but avoid overheating the sand.Pat you should be OK casting from those, the trick is to carefully wind the pattern out of the sand, the helix should allow it to unscrew.
