Philipintexas
- Apr 13, 2012
- 227
- 52
I can't find if this subject has been covered before, If so, I apologize. I use my Enco mill/drill extensively and found a couple things to speed up the process.
1. The draw-bar. I'm always misplacing the wrench & hammer, so I made an extention to the draw-bar that is essentially an in-place sliding hammer. These photos should explain how it works. In use I loosen the nut, lift the captive weight and drop it, this loosens the collet. The shaft has a milled out slot and a tension pin retains the sliding weight. The lower hex section allows me to tighten & loosen the bar even when fully lowered.
2. I can't take credit for the basic idea, but I added my own improvement based on lots of screw-ups. I'd get everything aligned, turn on the power and the torque of the motor would move the head because I forgot to tighten the bolts. So, I added the switch and a "finger", a piece of vacuum hose plug, to turn off power when the head is loosened and then turn it on only if the bolts are tightened by the swing arm. I added the hex heads to the securing "nuts" so I could torque both equally and then mark & drill for the two arms that actually secure the head.
I've used this gadget for about 15 years and it has saved countless hours in use.
HEAD SECURE, POWER ON:
HEAD LOOSE, POWER OFF:
FINGER ABOUT TO TURN POWER ON AFTER ADJUSTMENT:
