hedgehog.hedgehog said:how did you guys cut the .030" slit between the crank hole throws?
Hi Kevin.kustomkb said:Wow CS, moving right along eh?
Glad you decided to go for the sleeved cylinder as well I also prefer the look of polished Al.
They're right, better polish up your best shoes!
I did make it the same as the plans, the different angle of the 4 lobe cam will take care of the timing change.
My neodiums were a snug sliding fit and I added a drop of LT to make sure.
Hi Jason.Jasonb said:Hemmingways here in the UK still list the Exciter
http://www.hemingwaykits.com/acatalog/Ignition.html
Jason (yep I've got a hog on the go as well)
Hi RandalRCox said:Yep, I'm the guy that designed this thing.
Wandering around this site, I find several guys building the "Hoggie" ;
MatiR, kustomkb, and others, Awesome ! I'm flattered... :bow:
If I can be of help, I'll try to check in here from time to time.
I'm about finished with #4, (I'm hooked too) but since it seems Mike Neal has evidently quit the ignition business, I can't get another "exciter". This coil was perfect for the hoglet.
