My first runner, a scruffy old Stirling.
vlmarshall
I guess I'll post a bit about the first engine I built, about 12 years ago, a Stirling hot-air engine. This is my only remaining Stirling, one of them being destroyed, another lost, and the fourth was never finished.
This engine is based on Koichi Hirata's "LSE-01" engine, available here: http://www.bekkoame.ne.jp/~khirata/english/make.htm
I decided to build the engine as a horizontal, instead of the top-heavy vertical design in the plan.
While preparing to build this, I couldn't find the glass syringes the plans suggested using for the pistons and cylinders.
Instead, I made these parts from tool steel, heat-treating them all, and fitting the cylinders to the pistons on the Sunnen honing machine at work. The cylinder sleeves are pressed into aluminum mounting flanges, the working piston also includes fins, a glassbeaded texture, and a thin (now peeling) coating of flat-black paint, to help dispel heat.
The bore is increased to 13mm, but I left the stroke at the planned 8mm.
The crank runs on ball bearings, and both the flywheel and the displacer piston's crank throw are only secured with pairs of setscrews, so I could experiment with timing differences or change the running direction.
During my experimenting with this engine, I rolled up a bit of brass screen and pushed it into the transfer port between cylinders. That little bit of brass greatly increased the efficiency of the engine, increasing the run-on time after heat is removed. The brass pulls heat from the air that flows into the working cylinder, and after the air has cooled, gives back a bit of it's stored heat, 'preheating' the air just a little.
The hot cylinder cap is stainless steel, although you can't tell anymore. ;D
All of the material for this engine was picked out of the scrap bin.
12 years of shelves, demos, and experiments have left this thing looking a bit scruffy.
Thanks for looking.
-Vernon
Oh yeah, there's a video, too.
[ame]http://www.youtube.com/watch?v=WxEnP2mG3PI[/ame]
Hi Vernon, Great engine , like the video what sort of RPM's are you getting? what sort of configuration is the engine , dose it have a type/name?
Rob
Rob
Thanks! I'm not sure of the RPMs, I've never measured them!
This engine is a Gamma type with a regenerator, separate cylinders for each piston, running parallel to each other, with the timing offset 90 degrees at the crank. The 'regenerator' in this case is a little bit of brass screen. ;D
Nice runner Vernon!
Very nicely done! :bow:
Rick
Good one Vernon.
Best Regards
Nice job,
I've always wanted to build one of his engines.
Cool! Those are pretty serious looking connecting rods :)
Thanks, everyone. That thing was a fun build. Looking back at it now it's pretty ugly, but it certainly was built as a "runner" for experimentation, not as a showpiece. ;D
Yeah, for some reason I didn't cut down the center sections. I think the rods in the plan were just 1mm flatstock, and I beefed them up without much sculpting. I built this thing on a Bridgeport and a Hardinge lathe in less than a week of evenings at work after hours.
Actually, this is the good-looking side, I'm hiding the fact that the lightening holes in the other rod aren't all completed. :big:
zeeprogrammer said:
Proof! Proof of my suspicions!
Thanks Vernon. I enjoyed the video.
Yeah, yeah. :D
Thanks, Zee!
-Vernon
