Yse you need to lap teh crankshaft to the bearing and also lap teh barrel into the carb.
J
J
I hope you enjoy your holiday Gus. When you return, we will still be here to follow your next build.
You mention Melbourne and Sydney. If you are coming to Canberra, drop in and have a chat.
Jim
Personally, I still think your tank is positioned quite low relative to the venturi outlet (I assume the upper line). Your muffler must provide lots of back pressure to boost or 'lift fuel up hill' to this position (hydrostatic head) & it will only do that at relatively high rpm. Even when you get it running with the right needle valve setting like this, it will go lean as the fuel depletes so be careful of overheating.
J
