Very pretty models - I am sure all runs well. But I was an Engineer (not Mechanic, Machinist or Fitter) and I weep at the innocence of really good model builders when they simply haven't been taught the Engineering. ANY exposed copper is a No! No! The lost heat is most of what you expend your effort trying to get into the steam. Please lag the boiler and ALL steam pipes and fittings. If you want polished brass and copper, I suggest you make jewellery, or keep it for the cold parts, maker's plate, etc.
Also in "real" steam plant, the super heater is after the regulator for 2 reasons. One is safety - if the superheater fails you can shut the valve and shut-down the fire before you empty a full boiler of steam - the second reason is to get the super-heat as close to the engine as possible. Stuart models do it the other way for convenience.
Displacement lubricators do work with super-heated steam.
Traditionally, models were made as people were not so well educated that the Works owner or Manager could read drawings, so a model was an accurate representation and could explain many features to make the sale more easy. Even back in Egyptian times! Also more recently, models are a cheap way for the design to be proven, without the cost of the full sized job. But we all, including me, make these toys (not proper models) because we enjoy it. I applaude the expertise of the few real model makers.
It has to be your choice as to whether you want a functionally representative model, or a working toy. Be proud of whatever you choose to make. And please be careful to avoid burning down another workshop! A lesson for us all there. Thanks.
