After much research about machining titanium, I thought the only way to find out about machining this metal was to try it myself.
I bought some 9.5 and 12.7 mm rod from a WA supplier with the idea that I would use it to make the conrods for the small diesels I am interested in.
I was very pleasantly surprised to find it to be one of the nicest machining metals I have ever used. I did many cuts including some heavy and some of just one thou (.001") and the swarf came off like fairy floss. No hint of catching alight and the workpiece maintained a shine like polished aluminum.
I was using a Valenite DNMP-432-1W VC2 tip with about a 1mm radius, and I have found these to be terrific for any metal, including 41/40 and spring steel. They never seem to blunt, and the one I actually used has done well over 2 hours of work on all sorts of hard and soft metals.
The tiny centre drill used to spot the bigend and gudgeon pin holes went into the titanium quite nicely, maybe a little less easy than mild steel, and the cobalt drill had no problem drilling through it. I then used a reamer and hand turned the mill and it went into the Ti again about the same as steel.
I then tried the time honoured way of reducing the diameter around the gudgeon pin with a HSS slotting mill and again found the Ti just a little heavier than aluminum but not overly so.
To sum up, I would thoroughly recommend Ti for this type of application, it doesn't seem to have the inherent problems that I have read about in the way I have used it.
The bonus is the conrod weighs 4 grams !
I have prepared a .pdf file of the photos I took whilst machining it and it is attached just below the text here.
The conrod will go into the 5th model diesel engine thread - in the Plans forum on HMEM.
Ed
>pdf below ....
View attachment 25mm conrod in Ti.pdf
Ed
>pdf below ....
