Thank you all for your comments!
Martin - I don't have any plans to put the engine in a plane - I am too afraid of seeing my hard work take a nose-dive into the ground! :big:
The prop is towards the top end of the size range for this engine, I think. It is a 10x6 prop, the engine is 1.75cc (meant to be approx 1.6cc, but both the bore and stroke ended up being slightly more than the plan values). It was the only prop I had to hand that would fit onto the crankshaft without needing to be drilled out. I figured the larger diameter prop would provide more flywheel effect whilst the engine was running-in. It certainly doesn't seem to be overly stressed whilst turning it!
Once I cut the crankweb to balance the engine better, I will make some more runs and explore the engines performance a bit further...
Anthony
