LADmachining
- Sep 22, 2009
- 53
- 11
Hi all,
Though I would post some pictures of my current work-in-progress.
This is a replica of the Vivell 09 diesel from 1948, reproduced by the 'Motor Boys' with castings supplied by Roger Schroeder.
Construction was started on the 4th September 2009. To date, the following parts need completion:-
Connecting Rod, Piston, Rotary Valve, Fuel tank and cap, Needle valve, Prop driver, Contra piston.
Here are some 'in-progress' shots of some of the components:-
Crankcase
Cleaning up the front of the casting ready for marking out.
Casting marked out and set-up in the 4-jaw for boring and threading.
Screwcutting the case - 32tpi LH thread.
Parting-ff a plug to fit into the recess that has just been bored. This will be used when the cylinder recess is bored to ensure the deck height (distance from centre line of crank to top of casting is set correctly).
Completed plug with flat, which is a known distance from the centre of the plug.
Crankcase set-up on angle plate to bore cylinder recess.
Recess boring in progress...
Angle plate transferred to mill to drill mounting lugs and cylinder securing screws.
Cylinder
Cylinder fin cutting in progress....
More pictures to follow (if anyones interested :big....
Crankcase
Cylinder
