- Jul 16, 2007
- 3,028
- 1,119
Gentlemen,
I getting close to finishing the Woodpecker engine. The drawings call for a small stud to which is attached 2 small springs, one for the pushrod lever and one for the lock out lever. If one builds it as described the pushrod lever will be pulled up against the pushrod and away from the cam. This doesn't mean it wont' work but every engine I have ever built has a spring which holds the pushrod against the cam and the clearance is at the rocker arm end.
There are pictures of a finished engine on several internet sites.
These show a rod of some sort with a spring on it tucked in behind the rocker arm lever. Does anyone have an idea of how this works? The drawings don't spell out anything like this.
My last question is the operation of the 'points'. It call for a button mounted on the governor mechanism. This in turn will rub up against a spring steel lever which is mounted on the pushrod lever. How does one set the time with this contraption?
Thanks for any help,
gbritnell
gbritnell
