maybach_man
- Oct 28, 2012
- 22
- 9
Tracey tools is excellent for all types of taps and dies in the uk.
Thanks for the pictures and description, that's a nice tool and would definitely make bolt making a lot easier and with the depth stop, more productive, now the issue would be to find the hex stock of the correct size.Tool I made 20 years ago. It was based on a friends project after he saw one which
I think was in Modeltec magazine Here are some pictures. The unit is a box tool of sorts
View attachment 130179View attachment 130180View attachment 130181
By having different bushings, I can do hex stock, Square stock ( for sq bolts ) or round stock
In the picture you can see some threaded sq stock.
In operation, I feed stock into the tool and it reduces diameter to thread Size and length .
Then I withdraw the tool while the Lathe is still running and place the die holder ( and die) on the
front boss and feed the tool back into the stock while holding the knurled die holder.
The stock is quick threaded and I release the Die holder when the thread needed is achieved.
My hand being a clutch . Stop Lathe and reverse and I pull the die holder off.
Now I can use a Parting tool to separate the finished bolt, but I prefer to do it in "sticks"
That is, do both ends of the stock and maybe do 6 sticks that way .
Then set the Lathe for parting off a bolt -one stick at a time ...much faster
The square stock in the picture is a "stick"
Rich
Where can you buy model size nuts that look right on small engines? I am looking for 4-40 &6-32 in particular but could use other sizes if available. Thanks Colin
