Chuck--I am far from being expert---but---here's what I have learned. Firstly, the piston should be about .001 undersize from the bore inner diameter. I have had my best results using 600 grit abrasive in an oil base. You have to have some kind of handle on the piston---the connecting rod works just fine. Coat the i.d. of the cylinder with lapping compound and wiggle the piston a bit untill you get it started into the cylinder. It won't want to go in, as the .001 clearance is damn tight when you get the lapping compound on there. I put the cylinder in a vice so it can't run away on me, and work the piston back and forth (full stroke) in the bore. this requires a certain deftness of hand, as you don't want to push the piston all the way out the far end, nor pull it out from the near end. After you work it back and forth about a dozen times by hand, it will get much easier. You should now be able to rotate the piston in the cylinder, by hand. Now comes the terrifying part!!! Set your lathe on its slowest speed and grip the cylinder in the chuck, with the con rod hanging out the opposite end where you can grip it. Hold the con rod firmly in your right hand, say a short prayer, and turn the lathe on, while holding your breath and with your left hand poised over the stop button. If you have lived a good clean life, as I have, the cylinder will start to rotate, and the piston will not rip your arm out of the socket. As the cylinder rotates (I stress SLOWLY), work the piston through its full stroke in teh bore, being carefull not to push it all the way through nor pull it all the way out. Let the lathe run for about two minutes while working the piston through its full stroke. Shut the lathe off. Say another short prayer (Thank You, this time.) You're done!!! The piston and the bore should both now have a uniform dull color. Please note---This is what I DO. If anyone else tries this and ends up like that guy who was always being chased on The Fugitive, don't come looking for me.---Brian.
