My no name Chinese minimill has developed an intermittent fault.
The motor will suddenly slow down (under load) - ie it fails to up the torque (Amps) as you load it.
I compensate by turning the speed up but of course now the speed varies with load and shoots up to whatever you have dialed in when unloaded or when the fault clears.
The fact that it is intermittent is what I find curious.
Before I start trying to fix it I though I would ask the forum if anyone recognises this machine / circuit board / problem and can point me in the right direction or provide a schematic.
This is the board :-
The only marking I can see is LM1H1
This is the machine (if that helps) marked as a CH-10
Any help would be appreciated.
Ken
Ken
