Hi Animal, Timo,
I had a "problem" when I made a Stuart Sun engine... 180degree single acting twin steam engine - and decided to fit it into a boat. The engine (designed for continuous running, and used for "high speed torpedo boat models" more than 50 years ago) needed a transmission to change from Forward - Neutral - Reverse. So I made a relatively simple twin-disc and friction drive. This drive also was incorporated to drive the boiler feed pump, and change screw speed from the 300~2000rpm of the engine to something more useful for the boat. With a bit of trial and error, I developed this arrangement.
In this view you can see the RC servo, that drives a rod (with springs) that pushes the "collector" wheel from a central "neutral" position to either Drive wheel (a single steel bobbin driven from the engine). It didn't work with steel on steel, but worked well with an O-ring. Until the paint on the drive wheels got wet with steam condensation. So I knurled the faces of the drive wheels, when everything worked well. But the engine (4 1/2 lbs) was too heavy for the hull, so I changed it for a Stuart Star engine (2 lbs) and now the trim is good! The gearing (toothed belt drive) was changed to suit the "half-sized" engine, that runs faster, but develops the same sort of speed as with the Sun engine. The collector wheel - with toothed belt drive to the main-shaft, rotates on a bearing concentric with the main-shaft.
A few other photos show me tinkering, and the boat.
This drive does not permit speed variation, but on the pond, the boat was very manoeuvrable with forward-reverse working as planned.
Incidentally, the exhaust from the engine passes through a concentric tube condenser (using pond water as the heat sink) and returns it to the boiler via the flat collection tank and a feed pump driven off the "bobbin" shaft. I arranged the single acting feed-pump to have approx. 3 1/2turns to "Pump" and a single turn to "prime" as the pressure difference on the piston for the 2 strikes was significantly different (Atmos vs. Boiler 20psi), so would cause the engine to "slow-down and speed-up" as it pumps. It is nearly smooth with the "eccentric" drive, so the boat speed variation is not observable.
I have no drawings, as I wiped the black-board after making bits. But I'll draw it if anyone needs drawings.
Also: I suggest anyone who is interested should have a look at Torotrak transmission. =>
Torotrak Infinitely Variable Transmission -- articles & patents (rexresearch.com)
It inspired my simple FWD/N/Rev arrangement.
