Sorry it is taking so long gents, but when you can only work in ten minute bursts, even a small job becomes a major one.
So this time, I am making the jet and control valve holder. As far as I am concerned, the jet part is the most critical bit, because it not only has to be gas tight, it also has to be totally square to the main stack, otherwise the gas plume will be fired off to one side and maybe not burn correctly.
I started off by turning some stock down to be a snug sliding fit inside the body sleeve, and parted off to basic length. There is no mention, as far as I can recollect, of how all these bits are joined together, so I have decided to do some very fine silver soldering on mine, and that will require a small gap to allow for the capillary action of the silver solder and flux.
The holders were faced off each end to bring them to spot on length. Then each end was spot drilled. It didn't really need both ends doing, but with this build being so small, even having the base mounting screw slightly off centre will make the assembly look badly made.
On just the jet end, a chamfer is put onto the part. This is a certain size, as when assembled, this part extends slightly past the air inlet holes in the body sleeve. This chamfer allows the free flow of air from the holes to the jet area.
Each end was drilled to the correct size for tapping for my 8BA sized screws. For the drawing version, you would need to drill for 2-56 threading.
The holes didn't meet in the middle, they were drilled just deep enough to penetrate into the cross drilling area.
And this is where the cross drilling starts.
First off, by using my centre finder and a parallel clamped in the vice, I got the chuck spot on centre of the part diameter.
Now this is where things can get tricky. There is not much to grip on each end of the part for drilling the large cross hole. So I will show you how I got around it.
I will just mention now that you could hold the part across the vice, resting on parallels, but for a quantity amount, I didn't want to risk having the part not square across the jaws, hence the way I did mine. Just me being paranoid.
I am lucky in that I have some 3" long parallels, and by stacking them up, I could get to the height I wanted.
I put a strip of double sided tape across each pair, then clamped the pairs into the vice to leave the correct gap between them. All four were stuck to the fixed jaw, so that they won't move out of position.
The part was rested onto the parallels, equally, either side of the gap, with the jet end away from the backstop.
Then the back stop was brought into position, so that every part should end up in the same place each time.
With everything tightened up, I took a reading off the non jet end of the part, and positioned the chuck in the correct position for drilling.
The part was removed and the drill was checked for clearance as it went into the parallel area. It looks tight, but it isn't really, just a hoptical dillusion.
Part in position, and a fairly large spot drill put in. Because I am going thru in one hit, there is no way I want the large drill bit to wander as it goes down past those curved sides.
The drill is 1/64" smaller than the stated diameter. This is a reaming allowance for after assembly with the body sleeve.
I took it steady as it went thru, especially as it went past midway, where the two end drillings were. I didn't want to have an oversized hole at this late stage.
As it was, no gremlins appeared, and everything went very smoothly.
So back onto the lathe.
I broke out my mini tapping tool and power cut an 8BA thread into each end of each part.
After the first one was cut, I tried the screws that are to become the jets, just to make sure they were a good, non sloppy fit.
This shot also shows up a problem that normally happens with commercial screws. They just never get the threads right up to under the head, so an allowance has to be calculated to counteract the hold off gap that would be created if the screw and hole were left as they were. I usually use a length of 1.5 times the thread pitch (just roughly). For my 8BA threads, 0.025" will be fine.
So using a 3/32" milling cutter (just a little larger than the OD of the threads), I touched on, and then cut in the required amount.
As you can now see, the screw now goes all the way in, and I reckon, the jet will not require a sealing washer because of the good fit of the screw under the head and in the threads.
That's as far as I have got with the build, but because I was asked about my power tapping tool, I will show you that you don't have to spend big bucks to make tooling.
On the LHS you can see a commercial mini tap wrench, I bought this hundreds of years ago, and it is still going strong, maybe because it cost an arm and two legs back then, and I still think they are pricey now.
On the RHS is the way I got one for making my mini power tapper.
If you notice, it is part of a set of real cheapo pin vices. The commercial one has a square set to the jaws, but if you mount your tiny tap with the corners into the jaw slots, it clamps up just as well, and runs perfectly true.
The knurled part was turned down until the knurl was just gone, then the shaft was measured. An old large bolt was turned to the shape of the holder you see. I had it that shape so that it cannot be pushed right back into the chuck jaws, and maybe cause damage if something broke and the holder had a backwards knock.
A hole was drilled and reamed thru it, just smaller than the shaft on the modified pin vice.
Then the pin vice shaft was turned down until it was a nice snug sliding fit in the hole. A bit of 1/8" silver steel was loctited into a cross drilled hole.
Total cost, apart from a bit of time, about 4 or 5 bucks.
Slowly but surely, we are getting there.
Blogs
