Internals are done. Need to work one stuff like the cover, how I'm going to start it, ignition, carb.
The easy stuff
The easy stuff
Does it have a big flywheel? Maybe make a ring gear and go electric start.
No way. Has to be a pull start with a rope that won't go back in half the time.
Looks good Steve will you be releasing an more code on that engine my head is starting to get lonely.
I don't know. If I do then I would be on the hook for the entire engine and I don't even have the drawings done let alone a running prototype.
Sounds like you need to take a vacation so you can get some work done.![]()
Hi Steve:
I just found this thread. Man that's Amazing work as usual.
I have a simple question. What cutting fluid are you hand spraying on the milling machine?
Oh, and don't they have labor laws in "The Motor City"?28 straight days can't be legal.
Sage
Hi Steve:
Sorry to look past the wonderful work you've done on the engine hall sensor mount BUT, what do I see in the background. A wonderful antique car. I'll bet that's fun to drive.
You must have a big shop. Two vehicles end to end, well lit.....
Beautiful work.
Sage
