Speedy said:how did you go about scaling your frame down to size?
Don1966 said:Steve, Micromark has liquid rubber you can mold. It has different drying time depending on with one you buy. This rubber is see to make tires for models. They also sell mold silicone to make the molds with. I am sure you could make a mold to pour the rubber in, after all you have done so far on this mini bike :bow: small step for a stepper. I have been following your progress just being quiet here till now.
Don
mklotz said:They sell kiddy tricycle replacement hand grips. Is there any chance that they might be in scale?
steamer said:Tbe grips can be molded the same way as the boots
stevehuckss396 said:I doubt it. The inside diameter is only .3125. I would think they will be only 1.500 inches long or so.
I used the micromark products to make sparkplug boots for the Demon. The hard part for me would be making the mold. I imagine I would have to machine one in aluminum. Them make the mold from the aluminum one. Then I would need to make a core and figure out a way to register it on perfect center.
mklotz said:OK,
It was worth a try.
stevehuckss396 said:The boots were easy in that I machined a mold and went to work. These will require a few extra steps.
