This is a hexagonal mount ER32 collet chuck I use for milling hexagons :-
I just open the vice rotate the hex shank and continue - accurate enough for spanner flats and hexagons. An a lot easier than mounting the dividing head or rotary table.
See also my thread on using such a cheap and nasty vice - with a bit of finessing.:
Cheap & Nasty Vice Made Good
Initially I wasn't very happy with the accuracy but there was nothing wrong with the chuck - it was my vice(s) soft jaws and lifting during clamping - once I had that sorted no further problems.
However if I am milling an accurate hexagon I will still clock each face for accuracy rather than relying on something that has been "moved" but for this sort of job is fine.
You can of course mount the hexagonal shaft in a 3-Jaw as a quick conversion to an ER-32 - but kinda negates any accuracy you might be hoping to achieve with a collet.
(I have a different collet chuck for my lathe so I've actually never tried to do this.)
See also my post from way-back on grinding small hexagonal thingummbobs :-
Grinding Hexagon Thingumybobs
Regards, Ken I
Regards, Ken I
