Metric Taper Adapter Sleeve
Good to see you're making progress.
Rather than use a boring bar (which always seem to want to squeak at the most inappropriate time), is there anyway you could rig a shorter tool up-side down in a heavy tool-post? (e.g. a nice sharp HSS bit)
BTW I find it's better to have the gibs sliding nicely rather than too tight.
Bill
I finished it last weekend. Sorry I have not posted any progress pictures on the adapter. The chatter was due to the tool. I got it right after a couple attempts. One problem was having the proper angles ground. The other thing I learned was if the tool was not on center it would result in chatter and the taper would not be the proper angle. Anytime the tool began to chatter I would sharpen the tool. I have learned is when to sharpen the tool before it begins to chatter.
I'll post progress pictures later this morning.
The first two pictures are from my work to establish the inner taper angle. When I finally got everything right the work was too short to be used for the adapter. I renamed the scrap "gauge" to make me feel better. ;)
Rather than cutting off a piece of stock and possibly creating more scrap "gauges" I decided use the stock full length. I was a bit leary of the size at first. My cuts were not going to be to heavy as the belt is due for replacement and slips easily.
Once I finished the bore I cut it off. That was a bit tricky. I had to regrind the cut off tool as someone had decided that the sides had to have relief ground into it and caused alot of chatter. I did turn the outside diameter although it was not necessary.
Once I had finished the inner taper I needed to make an arbor to hold the part while I turned the outside taper. The photo shows the arbor with the taper turned to match the adapter.
I had to re-create the outer taper of the adapter. This taper must match the ID of the clutch. I used some stock to find the angle and then checked it with the clutch.
Once I had determined the outer taper of the adapter I put the adapter onto the arbor and turned the outer taper. I had to check several times as not only is the taper critical the depth of the adapter is also. I used a mic to get the rough cuts made. At one point I thought I blew past the OD and after a slight finish cut I found that it was almost dead on. I had to remove the bolt to check the fit with the clutch. It all came together quite well. ;D
Now that I had the taper adapter completed I had to remove it from the arbor. I placed two straight pieces of metal along the sides, with the bolt loosened I gave it a rap with a small hammer and the adapter came free of the arbor.
The finished adapter.
In case you were wondering. I have several chucks that I used. I kept the arbor in the same chuck so that I did not have to set it up again (between finding the angle of the outer taper and turning the outer taper on the arbor).
I found that during several conversations about how I was making this adapter people were suggesting machine shops that would make this for me. I have no idea what I would have been charged to have this made. I knew I could do it and actually was bothered that in one instance a man insisted that I give up and take it to a shop.
Nice work RV :)
Don't forget to show us a picture of the CVT mounted on the crank :)
