I have a setup where I'd like to measure engine oil pressure, but I've got a problem - the pressure pulsates violently. Rather than a nice, steady reading, like 30 PSI, my pressure gauge needle flails through +/- 10 PSI. Besides being distracting and not particularly elegant, it's destined to wreck the pressure gauge.
While I have things torn apart, I'm wondering if there is anything I can do to eliminate this. I have a glycerin-filled pressure gauge which should help. I'm thinking a tiny, tiny orifice somewhere in the line should dampen or eliminate pulsations. Since the oil has viscosity, the pressure pulses shouldn't be transmitted through the orifice.
I'm thinking a #80 drill through a brass round section, maybe 1/4" long, inserted in the line, should do the trick.
Am I on the right track?
