thissentenceisfalse
- Jul 21, 2011
- 10
- 0
Hello all, I guess this is my first post, although I have been lurking for a while.
I know this is a long shot because of individual designs and machining, but I am hoping some good will come out of all the knowledgeable folks here.
Back in august, I started Phillip Duclos' model Maverick hit and miss engine with the ratchet mechanism for the exhaust valve. I have it 95% complete and am trying to start it. I have had no luck starting flipping it by hand, so I have been using a cordless drill to turn it over at around 3-400 rpm. I have what I think is a decent spark. It is somewhat white in color, the gap is about 30 thou. I am savvy with diesel engines, but I literally do not know much about gasoline engines, never owned one, rarely work on one. The spark will jump a little over 3/8 gap from the wire to ground, so its a strong spark from the coil.
As far as compression and valves go, I can cover the spark plug hole with my finger and it will pop it off slightly every time even if I push hard. While running with the drill, I slowly open my needle valve and it will randomly fire, eventually firing close to every revolution, but its touchy. Also, the firings seem very weak to me, and it will definitely not run under its own power.
The ignition timing is set to almost top dead center, slightly retarded. I have the exhaust valve set so that the valve is closed very close to the top of the stroke. I have messed around with both timings with little progress.
I shone a flashlight down my intake tube, where the venturi is and the fuel is kinda spraying out, but not misting at all. I wonder if this is my problem?
I would like to know how many others have completed this engine, and what your experiences are with getting them running.
Any input is appreciated!
Anthony
Anthony
