Okay---A bit more about my successful test run. As I said in an earlier post, there are some things that no matter how well they are modelled in 3D, you still can't tell if they are going to work until you make the real part and "try it and see". I had no worries about the marble (actually an 11/16" diameter ball bearing) on the entering side of the escapement. All the marble had to do was fall down the hole. Gravity has seldom failed me!! It was on the other side, where the marble is pushed up thru the hole that had me worried. There isn't a lot of clearance on something like this, and I was worried that the marble would jam between the orbiting block on the crankshaft and the edge of the hole on the underside. The theoretical "intersection point" between the centerline of the escape hole on the underside of the top piece with the holes in it and the center of the orbiting block looked to me like it was going to be too tight and cause a jam, so I took my best guess and offset the intersection point .040" when I drilled the escape hole through the top piece. After finishing the top piece and bolting it in place, I dropped a marble into the entry side, and slowly rotated the crankshaft with the vice grips. Of course, the first thing that happened was that the "marble" fell out the open side of the twin angles and landed on my foot!!! (That is what the yellow side pieces in the latest 3D model are intended to prevent.) I tried again, only this time I held my thumb and finger over the open sides so the marble couldn't escape, and kept rotating the handle---and out popped the marble on the discharge side, slick as a whistle. I was so pleased that I fed 5 or 6 more marbles through, and nothing jammed up. I hunted around this evening and found some .045" stainless that I've been saving for years, and tomorrow morning I will make the side shields and bolt them in place. Once I get everything operating smoothly, I will post a video of the hand cranked version, before I get real serious about gears to make a reduction unit so the device can be driven be one of my i.c. engines.
