plz am doing a project on an old lathe machine.the machine has its contactor bad i want to knw the consequences of running the connection straight that is by-passing the contactor
Although, the 1hp motor on my lathe has been wired directly with a plug and relies on the switch on the wall outlet for stop and start. Been running like that for at least 40 years.
Most low power mini lathes have no motor starters. I have no idea on the border-line above which a motor starter is mandatory. Our desk fan/stand fan/ceiling fan have no starters.
True from what I have seen this applies to fractional horsepower motors.
The larges motor I have dealt with was a 1 hp dc motor and the circuit was set up to start the motor and minimum rpm and then speed up after the initial start up.
I think the lesson here is if the OEM installed a contator do not bypass it. If it is faulty replace it with a direct replacement or suitable substitute. If you are not qualified to determine suitable or not qualified to replace hire someone who is.
this is really not rocket science Look at the full load amperage on the motor, as a rough guess your starting switch or contactor needs to be at least 2x the amperage at the correct voltage , dc current may derate the switch slightly. Doing this decently also might allow you to have a reverse switch position on controls. The relay approach also allow you to have the machine be depowered when there's power interruption and the like, preventing accidental activation. it also allows for low voltage controls, may pay off in damp conditions and also allow for a nice big emergency off button, may save a life or limb. So if your motor is above say 1 hp think about going a relay starter approach and if under 1hp get serious and put a decent switch on it. an old toolmaker with all his fingers and thumbs... Chris
Hooper, you need to reach the wall to switch off? I recommend you read incident and accident reports for what you do. Not good engineering or work safe practice.
Phil
Melbourne Australia
