SignalFailure
- Jan 1, 2008
- 366
- 3
Quite a few engines call for a little brass 'saddle' mounted on the cylinder either to form the port face on an oscillating engine or to mount or contain the valve chest for slide/piston valve. Making a hole in a rectangular block of material then chopping it up would seem to be the obvious way for anyone with limited equipment (someone like me for example :big: ) but with the price of brass what it is and being a bit of a tightwad I wondered if it was possible to make them from the a minimum amount of material.
It seems the answer is yes; I needed two parts measuring 8x10mm with a 16mm concave diameter so I chucked a piece of 3/8" x 1" drilled the biggest hole without quite breaking through the edges then proceeded to bore out a 16mm 'hole'. A bit of sawing and filing left me with the required parts.
First pic is the work in progress, second is the parts soldered into place.
