Ken , If you want to learn Jigs and Fixtures, it will help if you understand
" 6 Degrees of Freedom" ( 6DOF)
Unfortunately , Most of the discussions on the net are not machining related and are pretty esoteric in Physics and or Robotics . As a retired Manufacturing Engineer, I taught my machinists this subject
I wish I could send you my Power Point but it is 55 megs in size .
The general stuff you read about , or watch on You tube shows the setup, but you need to understand WHY ! That is the secret of success ! Understanding 6 Degrees of Freedom allows you to do your own setups for some wild parts . I'll try to start off here with a major point of 6DOF from my slides without getting too deep i hope
The single most important concept to Learn today is called 3-2-1
Examples of a Plane are :
• A Table top
•Your Milling Table
•The Jaws on a Vise ( 2! )
•Surfaces on angle plates
2 P are 2 Points and define a Line o---------------o
1 P is a single point in space o
In the real world you see this
So in the above example there are 6 Degrees of freedom
You see the 3 -2-1 , and now a single opposite point is needed to control the object
This is the theory to understand for non-spherical objects, and use it to see how other people setups are made
Hope this helps
Rich
