Why are all lathes and mills made from cast iron?
Could I weld up a structure out of mild steel plate to use a a lathe base and frame? Then just face mill or fly cut the surfaces in a mill?
I think you would need to flame stress it right? So you weld it, machine it then flame de stress it. Then will it need to be machined again after the flame treatment?
If that is all that needs to be done, as opposed to using cast iron. I guess it is then possible to make a machine that would hold an okay tolerance then yes?
Any ideas how hot you have to get mild steel to stress relieve it? and for how long?
Peter
Peter
