A little late but here is the burner used on the last flame licker (a Scott) I am half way through building. I have built many dozens ceramic burners for steam engines for many years.
This first one is the main drawing, notice the venturi for speeding up the premixed gas and air. Where the jet goes through the holder it is adjustable back/fwardsto get the gas mix correct.
These are the bits made to drawings
This is the lot joined by silver (hard) soldering, rather than the suggested Loctite assembly. They are hard soldered as I find much less susceptible to fracture on the joints.
And just to prove it works, here is the video. Instead of a ceramic end, it is using a home made brass rose. I tried both types and came to the conclusion that because the flames are in open air, it would be better this way as the flames can be varied to a much longer length than with a ceramic one. But this method will work perfectly with ceramic.
I hope this helps a little
