Machining graphite pistons
David Morrow
This may already be obvious to some of you, but when I made my last graphite piston, I came up with a somewhat different approach to boring out the center. I used a Forstner bit which is normally used for woodworking. Graphite is so soft that the Forstner bit cuts through it like butter and gives a nice flat bottomed hole. They come in many sizes so, with the right sized bit, there may be no need for a boring bar to arrive at your final size. Just keep your vacuum running near by to suck up all that nasty black dust.
I have gotten some good results with Forstner Bits. Where do you find the graphite?
I love that "nasty black dust". It makes my lathe sooooo smooooth.
It also makes my hands and everything around it dirty of course.
Jim
I used a 2 flute end mill, it worked great and gave a square bottom.
Why... The Graphite Store... of course
So how do you select the type to use for Stirling engine pistons? They seem to have lots of types and sizes- the first one I pulled up was $2,999 !
Another source for graphite is ebay, that's were I got my last two pieces.
I just checked my last Graphite Store purchases.
Nov / 2012 : GT001593 - 2.00" x 7.75" long, Isomolded Graphite Rod, $25.56
Aug / 2009 : NC001360 Fine Extruded Graphite Rod, 1.25" x 24" long, GR008G, $45.43
Not sure why I ordered a different product on the second purchase unless it was an availability issue. But they both worked just fine.
