Handy tech tip: don't put an itty bitty part, with an hour's work in it, on a piece of wood on your welding bench, then decide to toss that piece of wood off your welding bench for fire safety. At least, not without retrieving your itty bitty time-consumed thing.
I never did mention -- this is going into a 3/8" diameter boring bar holder. Hence, the nominal diameter of the thing is 3/8". I'm cutting a grove of 7/16" diameter, so having a tool with an outer face of 3/8" diameter will, I hope, do a good job of providing clearance.
So on my first attempt I made the thing 7/16" in diameter. Looking at it, I decided that 3/8" would be better. So I turned a new bit out of tool steel, turned down the end of the shank, and got as far as actually making the cutter blank.
On my second try, I got a blank all cut out -- annulus cut on the lathe, bit end cut out with a hacksaw in the vice, then filed by hand to the rough shape, then back to the lathe for parting. This is where the handy tech-tip comes in -- that one is somewhere in my welding shop.
On my third try I did all the above, and managed not to lose the thing before it was brazed on. My original plan was to braze it on and immediately quench it. This may have worked, but I was so paranoid about not dropping it into the oil I pulled it out before it was really cool -- a file definitely touched it. This afternoon I got it all nice and "won't attract a magnet" hot, then quenched it properly -- it's plenty hard. I didn't draw it at all -- I'm going to make a few cuts with it and retire it, so I'll trade ease of heat treatment and no worries about softening it too much for (slight) worries about it being too brittle.
And if I screw it up, well, I have experience making these things...
The thing is all over oxidization and brass and a bit of brazing flux -- but going on the principle that beauty is what beauty does, based on the test cut it is, de-facto, beautiful. This thing works pretty darned good. There's a bit of vibration as it goes in (very reminiscent of parting off -- gosh, I wonder why that is?). But it leaves a very nice finish, and cuts a groove that's almost the right size -- it's just a hair over 1/16". Since I'll be making the mating part to fit, I'm just going to claim that I meant it to be that way all along, and proceed.
