- Aug 25, 2007
- 3,890
- 715
It's been a lousy week and today was a particularly lousy day! All my own fault!
Earlier this week, I knocked my Pentax digital SLR off the shelf and it fell 5 feet onto a hard floor. Needless to say, it doesn't work anymore.
Yesterday, I was trying to press the new plumbing tee on my plumbing parts into the base. I had turned out the threads in the floor flange because the pipe wouldn't fit in perpendicular to the base. I was going to just press in an unthreaded portion of pipe. All was good except the interference fit was too tight and I flattened the top of the tee trying to press it in. I took off the flattened tee, pressed out the cylinder liner, then attempted to use a short section of round rod to press the flattened part out round again. It worked, but in the process, it split the top of the tee.
So, today, I went to Home Depot and bought another plumbing tee. This time, in machining it out, I bored out one end too big so the cylinder liner would no longer fit. Next I turned a small ring to press into the too-large opening. I was turning out the ID of the ring to be a close fit with the outside of the cylinder liner and I, again, bored it out too far!
Tomorrow, I'll make another ring to press into the too so the cylinder liner will fit...
Chuck
Chuck
