Locomobile steam engine
Bob was a very creative and talented man, but I am sure you have you own talents too as demonstated by your drawings.
We all have to do our own thing.
Mike
Next step was to finish the valve packing guides and thread the covers.
I machined the cast iron steam chest cover, sorry for my vanity, I had to put my name on it, then lots of drilling to be able to bolt the covers on.
Next will be pistons.
I finally got back to my project after a couple of weeks. I was able to machine the pistons and rods.
I decided to make my own design 2 piece piston which will have a press on carbon teflon ring/rider in the center.
We use carbon teflon successfully in large compressors at my work. I will see how well it works with steam.
I don't intend to run very high pressure, probably less than 100 psi, so the steam will be wet.
Mike
Mike-
That is beautiful work there.
The Stanley's used a two piece piston.
I am not sure about the Mason.
Worst case, you can replace the pistons with some that have cast iron rings. I have had trouble with machining many many things, but I can actually make cast iron piston rings without much trouble. I just turn off a few extra in case I break one, but they are not that bad. I don't do the heat-treatment, but turn them oversize, cut the gap, spring them in on a mandrel, and then turn them to final size. I make them slightly wide, and then sand the sides on a flat plate until the fit into the slot in the piston with a little to spare.
Thanks for the encouragement. This is most time consuming project that I have taken on.
It's hard to be patient, life gets in the way of hobby time!!!
I will have to do some research on the Mason Steam Car, I am not familiar with that one.
Mike
Hi Mike,
Don't worry about it being time consuming - just keep plugging away at it!
Very nice looking machining that you are doing.
Kind regards,
Ron.
I made a few brass chips this weekend. I machined the crossheads for both cylinders.
Next will be the crosshead slides/frames. The originals in the articles were castings. I will be machining them from solid round bar. Not very efficient but I believe it will work ok.
Mike
I was able to start on the next parts for the locomobile. My preference would have been to cast the crosshead guide/bearing brackets, but I don't do cast iron yet and they needed to be strong. I started with some scrap stressproof (1144 steel) round bar I got from work and started whittling away.
I will end up milling more than half of the bar away before I am done. After I complete one I will try to saw some of the material away to save time. I am designing as I go.
In the last post I showed a photo of milling the crosshead slide/bearing bracket. I got ahead of myself with that post. Before I started milling I pre-machined the bar round and to length and calculated the bores to put in to save some milling later. I left a section of round stock when milling so I could go back and finish bore the crosshead bore after all of the milling was complete in case something warped or stress relieved. Lots of hours to go to complete these parts. Castings would certainly been faster to machine, but with pattern making time etc. probably sixes....
Mike
More progress on the bearing standards/crosshead guides.
I decided to work smarter instead of harder.
The first standard I removed all of the material by milling, a very slow process. The second standard I got a little smarter and machined a slot at each end and cut a large section out with my band saw. I saved at least 3-4 hours in the mill.
Here is a photo of one standard with most of the mill work done. The ring on the bottom I left to be able to chuck it up in the lathe for a final bore in the crosshead guide after all of the stress relieving caused by the large amount of milling on the piece. The other part is the vise is about 70% milled.
One chip at a time!!!!!
Mike
I am finally back at it again. I have all of the basic milling done on the uprights and am boring the crosshead guides. I had to extend my boring bar to the max and run at only 80 rpm to eliminate the chatter
The ring left on the bottom of the upright was for chucking purposes. I may leave part of it for an engine mount.
I was able to bore the crosshead guide bores successfully even though they were flimsy long parts. I had to machine with a very fine feed and slow rpm.
Because the parts were long I borrowed a right angle attachment for the bridgeport from work. This made drilling the holes in the top of the standards an easy job. Sorry about the blurry photo.
One chip at a time.
Allen,
Thanks for looking in and for sharing the photos. That looks like a fun project. I had not seen an engine like that before now.
Mke
Good night everyone. I'm new to the forum. I'm on research to build a full scale replica of a Locomobile or a Stanley Steamer, and at the moment I'm stock with the engine. So far I haven't been able to obtain enough information to work with. So I turned my expectations toward a Day-Land engine; so if anyone can direct me to get a copy or casted parts to start building one it would be really appreciated. Thanks in advance. Regards. JMV.
Nice build!
I am going to build a quarter scale 1906 Stanley 30HP race engine that was in the Rocket.
I'm hoping to cast around two dozen engines. I plan to use ceramic pistons with Viton seals.
I plan to use circular Viton discs sandwiched in between the ceramic discs.
The cylinder block will be lost wax cast in silicon bronze.
I have a friend that has the drawings that I plan to convert to a 3-D CAD drawing.
The drawings will be expensive but it will allow me to print 3-D models in ABS plastic for making RTV molds. These molds will be used for making wax models for the lost wax casting.
Giovanni,
Thanks for looking in. I will be excited to see the progress on your steam engine. Where did your friend get the Stanley drawings?
Would he be willing to sell or share if they are legal copies?
Mike
